WORKING WITH A BIZ HUB C 351 HAS A FS 603 ON IT THE CLUTCHES STARTED SLIPPING, AND FOLDING WRONG. THEN THE COPIER THREW A (C-11B1) CODE. I UNPLUGGED THE FINISHER. POWERED OFF THE COPIER EVEN UNPLUGGED THE COPIER AND LET IT SET AWHILE. BUT THIS CODE WILL NOT CLEAR. MANUAL SAYS IT IS A FINISHER PROBLEM AND SAYS TO UNPLUG THE FINISHER. I DID!!
WHY WON'T THE THING CLEAR WHEN THE FINISHER IS NOT PRESENT. AND.....I PUT THE FINISHER ON ANOTHER MACHINE , IT DOES NOT GIVE THE CODE. IT WORKS EVEN. THE CLUTCHES ARE STILL SLIPPING SO THE FOLDING IS OFF BUT IT FUNCTIONS AND NO CODE.
