konica 7728
  • mmbitar
    • 8
    [Error Code] konica 7728
    error code 50-1 at start up
    i am in need for servicemanual for konica 7729 or konica 9028
    thanks
  • DCPS
    • Mar 2008
    • 116
    "DESCRIPTION: F50-01 at power up. SOLUTION ID: 8778
    SOLUTION: PROBABLE CAUSES:
    1. Loss of 24V DC from the DCPS. Check the continuity of all 24V DC loads to ground for possible
    cause of the voltage loss. Replace the DCPS (p/n 504084510) after replacing or repairing the
    shorted load.
    7728
    2. ICP1 on control board 3 (CB3) is open resulting in loss of 5V DC (LED3 on CB3 will be OFF).
    Check for a short to ground in the paper feed unit wiring harness at CN31-9; CN33-A1, B1, and A8;
    and CN40-5. Make the necessary repairs and replace CB3 (p/n 5042-9020)"
