Konica Minolta Di 7210 Edh Registration
  • Rudi
    • Jun 2007
    • 251
    HI ALL
    I SEEM TO HAVE A PROBLEM ON A DI 7210 , WHERE THE REGISTRATION IS ABOUT 20 mm OUT WHEN COPYING THROUGH THE EDH , FROM THE GLASS ITS FINE .
    ANY SUGGESTIONS OR ADVICE PLEASE.
    ps. I DID REPLACE THE TAKE UP , FEED , SEP ROLLERS AND ALSO THE CLUTCH AT THE BACK ON THE DRIVE SECTION.
  • tashima
    Tashima
    • Apr 2007
    • 10
    see the registration menu
    you must to see in the edh menu the correspondient item to advance the reg to desired measure
    • Rudi
      • Jun 2007
      • 251
      I Did Check , But The Cut Off Was Not Permanent It Was Intermitend Wat I Did Find Was Replacing The White Guide That Sits Right Above The Reader Glass When Closing The Edh Helped And Also Losening The 3 Screws Left Of The Edh Wich Adjusts The Presure On The Transport Roller Helped Too.
