di3010 scan set up
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    di3010 scan set up
    hey guys.how do you set up a 3010 for scan on network ?
  • Johnny_B500
    • Mar 2007
    • 24
    I don't believe that feature is supported on the 3010, just Bizhub 200's and up.
    • Hansoon
      • Sep 2007
      • 3383
      Does it have the optional Scanunit SU-2?
      Hans
      • aleksander
        • 378
        you must installed Pi3505e, NC4 and SU2. Next, you need to install pagescope cabinet in your PC.
        • Hansoon
          • Sep 2007
          • 3383
          Not necessarily, FTP server/utility will do and works very good but your right Aleksander, to put the SU-2 it needs ofcourse Pi-3505 controller and NIC NC-4.
          Hans
          • SKTeK315
            Walter
            • Jun 2009
            • 142
            Thank u all. Everything is in & fine. I even installed a fax board w/op-panel. Fax works. Got both scan & print cards. We've got print. We've got a web interface. Not shore if it's thru pagescope or Mozilla.
            Mach config shows network, fax & print. So do the func keys. I need to know what & how step by step either or both ways to set up scan. FTP &/or SMB ways. Please. Thank u.
            ( also. It does let me set up to scan to email. Not what I need. I need it to scan to their sever ).
            Last edited by SKTeK315; 05-12-2010, 03:30 AM. Reason: Need to add more info to my question
