Bizhub 350 Error message displayed
  • aleksander
    • 378
    Hi all, have you ever have any experience in bizhub 350 error message? error displayed on LCD control panel. I tried to rewriting the firmware, and the bizhub 350 run well. But the day after, error occurs again. Anyone have any experience? What's the real problem?
    Thank you for any solutions.
  • Cantechman
    • Nov 2008
    • 228
    What is the error displayed?
    • aleksander
      • 378
      Just "Error" on touch panel. Nothing else.
      • rferdi91
        • Jan 2011
        • 21
        Re: Bizhub 350 Error message displayed
        try to change the MEMS Card on the mfbs board
        • JR2ALTA
          • Feb 2010
          • 2033
          it doesn't just say "error"
          • Hansoon
            • Sep 2007
            • 3391
            Exactly, furthermore would it be interesting to know if this is the B&W BH-350 or the color BH-C-350 since they are often mixed up.
            Hans
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              I think I had one do that. Thought I had a laser issue. Was writing blocks of solid black and thick lines. Changing laser did not fix it. I then pulled and reseated the MFB. Booted machine and the control panel went nuts. Had lines though it, like a damaged screen, and displayed "ERROR". I replaced the MFB to fix it. It was a BZ250.
              When you make the copier you think you know inside and out, say things you have never seen it say before, that is an "OH FUCK" moment.
