Bizhub C360 Jamming tray1
  • racosta
    • 53
    [Jamming] Bizhub C360 Jamming tray1
    Hey guys I have a C360 with intermittent jams out of tray 1. First time working on this model and I don't have a service manual for it just yet. I've been through all the usaual suspects as far as removing cleaning and putting back together. Still same problem. Paper makes it out fo the tray and stops rite at the vertical sensor flag. All other trays work just fine. Any Ideas would be greatly appreciated Thanks
  • BIG PAPA
    Da Boss
    • 234
    Intermittent jam code 1144 when feeding from the first tray.
    Description:
    Jam code 11-44.
    Solution:
    CAUSE: Failure of 1st Paper Feed assembly.
    SOLUTION: Replace the 1st Paper Feed assembly (p/n A0ED R731 00 for bizhub C280/C360 and p/n A0ED R732 00 for bizhub C220).
    sigpic
    • racosta
      • 53
      Thanks Big Papa for your reply. Yes I'm getting 1144 jam codes, but is there any other solution than replacing the whole feed assembly? Is there a clutch or spring or oneway that could be replaced instead of the whole feed head?
      • BIG PAPA
        Da Boss
        • 234
        Not sure on that. We had a new placement start this right after install and this is SSD's solution, so we are doing it under warranty. Part has been on back order for awhile now, not sure what they changed, will examine it when we ever get it.
        sigpic
        • tech51
          • 846
          The clutches nearly always cause this problem. We remove and clean the clutches in both feed units and this cures this 99 percent of the time...
          • racosta
            • 53
            Thanks guys.. I actualy just got back from the account and thats what I did. Last time I just looked at the clutches and blew them out since they were not making any unusual noise and cleaned the oneways and shafts and rollers. But today I took the clutch apart cleaned it and swaped oneways from feed to pick up and ajdusted the tension on the sep assembly spring and now it's running fine. Thanks again....
            • lucky13
              • May 2008
              • 125
              also check clear plastic paper guid on right side see if both springs are still on. mine came from factory with no springs also tray 1 and 2 had many mods done to them.
              • racosta
                • 53
                Thanks ... I saw those springs and they were on correctly. Haven't heard from them at all since I was there last. What kind of mods have been done?
                • lucky13
                  • May 2008
                  • 125
                  here are some mods
                  • racosta
                    • 53
                    • Spidula
                      Konica Minolta Technician
                      • 83
                      Hello Folks
                      Handy post for me this one.
                      I'm about to go back to a 280 which is having 11-44 jam codes. The M/C has only been in there 3 weeks. I couldn't get it to jam when I was there (usual story) so am gonna go for info I pulled of konica info-hub which states over tightening of the wiring loom. Looked OK on inspection but possibly split wire inside the sheath. I'm now armed with your info too, so thanks guys. I will attach the info I have also.
                      Will keep you posted!!
                      • Spidula
                        • 83
                        Fitted the loom today and give the clutch a clean out. Ran 750+ through tray one. Not one jam! Looks like its sorted, but you never know right techies!!
