KM c450 error code c2257
+ More Options
Posts
  • chriscctx
    • Mar 2010
    • 37
    Konica Minolta Bizhub C450
    getting an error code of c2257
    Can someone tell me what that is and how to fix.
  • KM GUY
    • 10
    A 2257 could mean that your tranfer belt cleaning assembly is bound up with toner or a gear is damaged, pull transfer belt assembly and turn cleaning unit gears by hand
    • iconzap
      c2257 in the lower model c250 is low toner. try to put a new toner and replenish toner.
      • chriscctx
        • Mar 2010
        • 37
        thanks KM Guy - I pulled the transfer unit out and there is a problem with that gear. I switched transfer belts with another unit and it fixed the problem on that machine and caused
        the same problem on the unit I put that transfer belt in. The gear on that transfer belt is bent like. Don't know what caused that. But thanks for pointing me in the right direction.
        • Jonzeboy
          It's sometimes caused when the customer replace the toner waste box and dont insert it properly...
