SLOW PRINTING WITH pdf. B 350
  • Rudi
    • Jun 2007
    • 251
    Hi All
    Our It Engineer Came Across A Problem The Other Day On A Bizhub 350 , Problem Being , When Printing Through Pdf The Machine Prints Very Slow On Al Other Applications (word,exel.etc) It Prints Normal The Problem Is Only With Pdf.
  • TonerMonkey
    • Jun 2005
    • 71
    Try using the postscript driver - are you using PCL cos it sounds like your customer may be ?
    • Scott_Lewis
      • Mar 2007
      • 519
      Make sure the Adobe Reader doesn't have the 'print as image' selected. This will slow printing by about a 20:1 factor.
      • Rudi
        • Jun 2007
        • 251
        Thanks A Lot Guys , I Will Give The Info Through To Him And Get Back To You .
        • random
          Does it have a fiery?
          If so there is one specific patch that needs to go on LAST.
          • skirt_chaser
            PostScript chip ?
            Is there a postscript chip option that can be installed on the print board ?
            • TonerMonkey
              • Jun 2005
              • 71
              With all due respect, in addition to the previous comments:
              It would be a colour C350 if it were to have a Fiery and it's only older Konica products that have a PostScript chip fitted to the NIC.
              Thanks for your input guys.
              • random
                DOH!
                Sorry half reader - I will check with our tech he has bound to have struck this.
                • AusiTech
                  Where in reader ?? file print? or in document?
                  cheers
                  • random
                    Advanced
                    Usually on the bottom left of the print dialog (not in properties)
                    • Scott_Lewis
                      • Mar 2007
                      • 519
                      Thanks, Random.
                      That was done so nicely.
                      • random
                        Also watch out for
                        Watch for PDF's that are scans rather than acrobat documents. These are images and regardless of if print as image is selected or not it will print slowly as each page IS and image rather than just text.
                        Not being able to select text is dead give away it is an scanned image.
                        • AusiTech
                          Cool thanks Random. Sorry for delay been on hols.
                          • konisolver
                            System Engineer
                            • Oct 2007
                            • 136
                            Upgrade the unit to ver 70 then make sure to select printer in the user mode instead of copier. This will make it print much faster.
                            • Juggy
                              Technical Support
                              • Sep 2007
                              • 101
                              what kind of pdf version is printed. Version 1.5 / 1.6 or 1.7. If version 1.5 and down is used download pdf direct print utility from the konica minolta site and try printing pdf. you dont need any pdf viewer or software to print. Just right click the file needed to print select pdf direct print and its atleast 5 times faster than any other software printing
