Help me! Network problems regarding konica minolta 7222 photocopier
  • cool_guy
    • Jun 2025
    [Misc] Help me! Network problems regarding konica minolta 7222 photocopier
    hello every one
    I want to connect my KONICA MINOLTA 7555 photocopier on a network. The situation is, i have four PC's that are networked through a 8 port switch. I connected my photocopier to one port of switch and i enabled DHCP on a photocopier. the switch automatically assign a IP address to a photocopier, the printout of photocopier TCP/ IP setting is
    TCP/IP Setup == ON
    Subnet mask == 255.255.255.0
    Enabled DHCP == ON
    Other DNS Server == 202.163.96.4
    IP Address == 192.168.1.37
    Default Gateway == 192.168.1.1
    Preferred DNS Server == 202.163.96.3
    RAW Port Number == 9100
    I downloaded PCL_6 printer drivers for 7222 Photocopier on one PC of the network then i add photocopier as a printer through "ADD PRINTER WIZARD" I selected a new "STANDARD TCP/IP PORT" in the wizard.
    Place IP address of the photocopier (192.168.1.37) and Port name (IP_192.168.1.37) then i selected "GENERIC NETWORK CARD" as device type then next then finish then i install PCL_6 printer drivers then next and then shared this printer on a network then a test page option said, "Do you want to print a test page?" i selected yes.
    But i was very frustrated when saw "TEST PAGE FAILED TO PRINT"
    one more point i also pinging the photocopier from one PC of that network, the pinging is successful but "TEST PAGE FAILED TO PRINT" can't imagine it.
    Can any one help me in solving this problem??? Any help will be very appriciated.
  • mikeL
    Some basics first:-
    Have you tried unplugging the 7555 and pinging the device again, or use a web browser to make sure it is the device that is replying to your Ping.
    • cool_guy
      i havenot tried to unplug the device then pinging it again. Actually i ping the IP address of photocopier and i get contineous reply from that.
      • mikeL
        If you unplug the Copier while continously pinging. if the reply continues, then there is another device with the same IPaddress.
        I would also suggest using a static IP address for the printer or at least reserve the iP address on the switch where you are getting the DHCP lease address from. This will save issues if the switch gets reset and issues another IPaddress to the Copier.
        • cool_guy
          ok i will check the pinging the device while unplugging it
          ok tell me how can i give static ip address to the photocopier??
          • mikeL
            you need to find a static IP address that is outside of the DHCP Range of the Switch/Router. (you may need to web browse the switch/router) find the upper limit of the DHCP Range and allocate the copier an ip address outside of the dhcp range. Ping the address to make sure nothing else is using it first. I.E. if the dhcp range max number is 192.168.1.100 you could allocate 192.168.1.150 etc. just make sure it is a legal address on the same subnet as the computers and nothing else is using it.
            • cool_guy
              thanks for contineous reply
              tell me how can i find static IP address (that is outside of the DHCP Range of the Switch/Router) using web browse the switch??
              • mikeL
                Use one of the computers to web browse to :- 192.168.1.1
                this is probably the router address - Default Gateway == 192.168.1.1, you should be able to get the information from here.
                • cool_guy
                  Since i have a DSL connection
                  when i web browse to 192.168.1.1 it gives me this useful information
                  DEVICE INFORMATION
                  Host Name == P-660R-T1v2
                  Model Number == P-660R-T1 v2
                  MAC Address == 00:19:cb:4f:d0:5f
                  ZyNOS Firmware Version == V3.40(AZP0) | 09/07/2007
                  DSL Firmware Version == DMT FwVer: 3.5.18.8_A_TC
                  WAN Information
                  DSL Mode == ADSL2+ Mode
                  IP Address == 124.29.247.120
                  IP Subnet Mask == 255.255.255.255
                  Default Gateway == N/A
                  VPI/VCI == 0/35
                  LAN Information
                  IP Address == 192.168.1.1
                  IP Subnet Mask == 255.255.255.0
                  DHCP == Server
                  Now tell me what is the upper and lower limit of DHCP range, i think the upper limit is 192.168.1.1 Am i right??
                  OK now i m telling you one more thing that i checked IP addresses of all 4 PC's of the network, it gave me this
                  PC1 = 192.168.1.33
                  PC2 = 192.168.1.34 (My PC from which i m pinging the copier)
                  PC3 = 192.168.1.35
                  PC4 = 192.168.1.36
                  Photocopier = 192.168.1.37
                  These are all the IP's given by DHCP
                  now which static IP i should give to photocopier??
                  • chromoholic
                    Make sure when the TCP/IP port was created the Raw Port Number is 9100.
                    This is under the Ports Tab in the Printers Properties > Configure Port > Raw Settings
                    Also as simple as it sounds.....check that you didn't type in the wrong ip address when creating the TCP/IP port.
                    • cool_guy
                      thanks all....actually i hav fixed my problem all the settings that i made for the photocopier are correct...when i contact the local konica minolta distributor they said that there is no printer card installed in my 7222 photocopier model...they further said that i have to installed the printer card, only then the copier printer function works
                      thanks all for contineous replies
                      • totoket99
                        I think your problem is that by default the PLC driver has "password" print checked in the options tab in the printer properties. Uncheck this box and you should be good to go.
                        Regards
