Document Scan using Pi3502 for Minolta Copiers
  • Bsmith
    • May 2010
    • 10
    I have just installed Pi3502 on Minolta copier, it works OK for printing. I want to enable the scan mode, what do I have to Do?
    Thanks,
  • Morlock49
    • Mar 2009
    • 166
    make sure the Postscript / Scan and 128meg upgrades are fitted to the Pi3502
    Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
    • TheOwl
      • Nov 2008
      • 1732
      Agreed with Morlock. You must have these options.
      Open up the Pi3502 and you should find a Smart Card card slot. This slot should have the upgrade kit (smart card) inserted before scanning then becomes available.
      • Bsmith
        • May 2010
        • 10
        Thanks for the direction!
        Please direct me to the source of the smart card.
        • TheOwl
          • Nov 2008
          • 1732
          You would need to find one on ebay or a Konica Minolta reseller.
          Chances are that you will have tough time finding the upgrade and it might be easier to find another Pi3502 with the scanner upgrade already installed.
          • Morlock49
            • Mar 2009
            • 166
            also it is probably going to cost you an arm and a leg for the postscript/scan kit. last one i seen for sale was over $350.00 and now they are getting rarer than rocking horse crap.
            • Hansoon
              • Sep 2007
              • 3401
              I still have some from returning rentals.
              Send me a PM or an e-mail nospam@rex-technika.com
              Hans
              • Bsmith
                • May 2010
                • 10
                Hansoon,
                An email is sent to you with my contact information and shipping address.
                Thanks for help!!
                BSmith
                • Apostolis
                  • Jun 2008
                  • 20
                  this upgrate memory for the Pi3502/5501/4700e controllers its a simple old 128Mb/ PC100-122Mhz one side memory.Its chipest - if you find
                  • Bsmith
                    • May 2010
                    • 10
                    Dear Apostolis,
                    Thanks for the details of th memory stick. I can look around and get one.
                    Second item is the issue, do you know any source for the second item?
                    • Apostolis
                      • Jun 2008
                      • 20
                      the scanner work fine too,with 64MB-PC100/PC133 one side (84 pin) SDRAM memorie's .If it's hard to find one side (84pin) SDRAM 128MB or 64MB-PC100/PC133,
                      you can use 256MB-PC100/PC133 two side (168pin) SDRAM , In this case the controller will accept the one side (128MB) of the sdram.I think you can find on ebay this memories and the minolta PS module.
