c 250 black toner
  • faisal jilani
    saad jilani
    • Sep 2008
    • 40
    c 250 black toner
    hi,i have 1 machine for bizhub c 250 this machine showing need k toner i replace the toner but it is same.i need help thanks.
  • Tonerjockey.com
    • Jun 2010
    • 41
    Those toners have a microchip in them. It happens that they fail out of the box. Try another toner. If that doesn't work, you may have a bigger problem with the control boards or firmware on the machine.
    • chexin51
      • Aug 2008
      • 37
      It also can be a problem with the Hopper Drive Assy but you will get codes C2552 - if no codes disregard this advice
      Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
      Solution: Replaced 4038-R729-00 Hopper Drive Assy ( C250 part compatible with C252 )
      Upon examining the defective part it was discovered that the coupling would slip for
      1/3 turn before grabbing and since the motor driving would only drive for 1/2 second
      each time it tries to add toner, no toner is added. The reason the coupling slips is
      because the wrap spring behind the coupling had come out of position and the end of
      the spring no longer fit into the coupling allowing a 1/4 free rotation before contacting
      the coupling.
      To change this Hopper Drive Assy is at least 3 hours labour
      * * * to diagnose a C2552 2554 2556 2557 code the following procedure could determine
      if this spring has come out of the coupling:
      1. remove the toner cartridge that corresponds with the code
      2. using a piece of wood the length of the toner cartridge or longer, place a piece of sticky
      putty ( Lepages - blue in color ) on the end
      3. while running TCR Toner Supply to the appropriate color, insert the baton with the sticky
      putty to contact the coupling while the the machine tries to add toner
      4. if the coupling turns the stick - this part is OK
      if the coupling is unable to rotate the stick at least half a turn - the spring is out of position
      and the Drive Assy must be replaced
      • gvl
        • 3
        replace toner k
