C2557
  • CCS@yahoo
    • Mar 2009
    • 14
    C2557
    Konica Minolta Bizhub 200 - code "C2557" and how do I access counters
  • CCS@yahoo
    • Mar 2009
    • 14
    c2557 - ATDC MALFUNCT. S0,S1 oooooooo end
    • fishleg
      • Mar 2009
      • 426
      leave the door open . The way I always dev these 1. Do the unit replace drum dev 2. Open side door 3. reset counters in service mode 4. go into f8 instant you shut the door press start you may have to exit f8 then go into it again after shutting door. Any other way seems to end in disaster with these machines btw 250 sucks balls unit doesnt last 5 minutes.
      • hussain
        • 28
        refer service manual, that will tell you the type of error code
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          If you do not know where he counters are, you will have a hard time with the drum and developer. If you are a tech for different brand, get a manual. That code can come from someone resetting the counter prematurely. Machine will run forever if you know what you are doing.
