Konica 7075 with IP 601
  • arcdigi
    • May 2010
    • 32
    What is the cable that I need to go between the copier and the computer unit.....I just bought this and there were no cords connecting the two......but there are several options on each unit
  • costel fasola
    • Jun 2010
    • 69
    between computer and the controller - network cable.
    between controller and copier is need special cable some usb cable but is not usb.
    • arcdigi
      • May 2010
      • 32
      Righ tI know it is a special cable and need to figure out which one it is....in the manual it looks like a parallel cable on one end but it doesn't show the other end
      • remati
        • 149
        ...you need a special cable (special usb cable )that cames with de tower IP 601 and the Video interface board...
        • langelot
          • Nov 2008
          • 85
          Its IEEE1394 cable better known as a firewire cable with the six circuit male connectors at both ends (important) - this was probably the original version of that cable - you can easily get it at a computer store - just make sure they understand that its for older equipment. You can find more info here at the wiki site on it - IEEE 1394 interface - Wikipedia, the free encyclopedia - good luck.
