Konica 7033 lcd initial display
  • mdm7266
    • Dec 2007
    • 99
    hello there. my problem with this konica 7033 is that when i initialized it 47 - 93 , the message on the lcd panel changed. when you turn the power on it displays the basic screen density adjustment, magnification, tray, but i cannot select to adjust it on lcd screen, i had to press the bottom menus to activate screen.
    it is not like that before, you can adjust the density step by step on the arrow on the lcd. do you know some programs to adjust so that the basic lcd screen buttons can be activated?
  • langelot
    • Nov 2008
    • 85
    When doing the 47-93 you've reset a few dip-switches, including the one that controls the full-auto screen to the factory defaults. Anyhow, go to 25 mode (same way you accessed 47 mode) pressing 2 & 5 while turning on the machine. Go to the menu for dip-switches and change address 7-7 to a 0 - if per chance it is already set at a zero, then change it to a 1. Turn off the machine, turn it back on and voila! it should work - let me know.
    • mdm7266
      • Dec 2007
      • 99
      already solved the problem. its on the software switch settings. thanks..
