bizhub 160 black copies
  • brent
    • Nov 2008
    • 1212
    so the scanner tries to work. but no light. copies are pitch black. and the copier comes up with a code. wront tc? is this just a simple change out of the image reader/scanner? when you shut it off it does work however. crazy thing. thanks for any help.
    brent
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    what code comes up?
    • TheOwl
      • Nov 2008
      • 1732
      Just make sure that the connection from the scanner to the main body is correctly inserted.
      I have had a couple with a dodgy connection even though the connector looks like it is connected correctly.
