c 253
  • rprem
    • 49
    c 253
    hai
    Km c-253 before the problem the machine was working good and proper colour was not coming so i pump the toner while the machine was running the current goes after that when i switch on the machine the minolta logo appears on the screen and nothing happens
    so i upgrade the firmware also but still the same problem.
    any ideasc
    Head Lines Are Made When Dead Lines Are Met
  • perdana
    • Jan 2008
    • 62
    You must chenge the NV Ram !
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      NVRAM recovery tool...you flash the machine in the same way you do normal firmware. The version you need in this case....
      A02E0Y0-F000-G
      DQ-J8
      If that does not correct the problem, you will need to replace NVRAM. You will need to contact Tech Support to generate a ticket on the matter so they can send you a replacement NVRAM.
      If it does correct the problem, simply reflash with latest after that.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
