BIZ pro 920 sc49-01
  • remati
    • 149
    [Error Code] BIZ pro 920 sc49-01
    ..Hello people
    any idea about error code sc 49-01 in bizhub 920.....
    thanks for the help...
  • Sharanman
    • 14
    the code relates to the ic 203 on the back of the machine the description is as follows
    SC49-01*1 The communication from IC-203
    to the overall control board
    (OACB) is blocked.
    The main body
    stops immediately
    to turn OFF
    the main relay
    (RL1).
    VI
    Try switching off from mains and restart from complete power isolation.
    • tech51
      • 846
      Had one last week do this. It was corrupt firmware on the IC-203. You may have to re-format the CF card and re-load the firmware...
      • remati
        • 149
        people thanks to all...
        the problem is solved ..-only disconected de IC 203 from de machine;clean it inside disassemble de board OACB and assemble again few minutes later...I think this work like a reset.......
