bizhub c-450 (Imagistics cm 4520) c-4765
  • karim-tech
    • 47
    This code is a hardware time-out.
    i clean up all data but the code still on ,
    i need the installation manuel if you can help that will be graceful.
  • oem
    Trouble code C4765 - Extraction hardware timeout [Description]
    Intermitted C4765 will be displayed
    [Solution]
    1) Confirm that the Memory dimms are set correctly.
    2) If this does not help, exchange the Memory dimms.
    • karim-tech
      • 47
      thx i will tray this
      • karim-tech
        • 47
        i need to know how can i reinstall it and the firmware
