Warming up on bizhub 600
  • aleksander
    • 378
    Hi all
    Anyone know the solution for warming up problem on bizhub 600?
    "now Warming up" shown during time in panel and never being "Ready to copy". Whats wrong with my bizhub 600? Any solution I will appreciate. Thank you.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    A lot of times on a kONICA, it is looking for toner when it is warming up. It will stick on please wait, if the patch sensor for the drum is dirty.
    • Rudi
      • Jun 2007
      • 251
      Excactly what fixthecopier says , only had this on the 2 sensors being dirty, no toner or toner gear broken on the supply unit.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Fix is right! I had one yesterday, when I removed the drum carriage and the cover the cleaning section was overflowing with toner I rescheduled for a recycle clutch and all is well. Of course cleaning the sensors solved the warm up issue, I just wanted to point out in my case the sensors were polluted due to a bad clutch.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • aleksander
          • 378
          I tried to clean the drum sensors but still "Now warming up". Then I try to replace the drum sensors and still the same problem.
          Any other solutions? Thank you for responding.
          • aesthetics1
            • May 2010
            • 148
            This can also be caused by outdated/corrupt firmware. Try updating your machine to the latest firmware using a USB Thumb Drive... This is 99.9% of the time the aforementioned sensors though. Double and triple check them.
            • aleksander
              • 378
              I dont know why. But my bizhub 600 works normaly.
              Next problem, when I used the bizhub 600 for copying more than 100 sheets, black background shown. Any suggestion?
              • chand226
                • 38
                Re: Warming up on bizhub 600
                no need of to change any firmware and drum.
                i have 200% correct formula for this copier (biz600/750/ di7210/7272). no toner on corona, no warming up, pleasewait.
                contact me at chand226@gmail.com
                • chand226
                  • 38
                  Hi all
                  • chand226
                    • 38
                    • Synaux
                      • Mar 2012
                      • 1224
                      Thanks for reviving a 3+ year old post...jackass.
                      • chand226
                        • 38
                        lol
                        then what?
                        • Synaux
                          • Mar 2012
                          • 1224
                          lol
                          then what?
                          I don't know. You tell us. Your the one spamming up the forum.
                          • techrep
                            • May 2023
                            • 5
                            i have face this problem..i only thing to do is.i clean the sensor and nothing happen..and then i check the thermostat and i just it.solve my problem the distance of the thermostat and the roller.
