Bizhub 601 Copy Firmware from CF to Other CF
  • Wasfil
    • May 2008
    • 20
    How to copy firmware from Compact Flash Bizhub 601 to other CF? because i have aproblem with 601, appears sand clock, and can't upgrade with normal prochedure (Using Flashdisk).
    Thanks guys,
  • TheOwl
    • Nov 2008
    • 1732
    Check through out the forum as there quite a few posts about this problem.
    One of the big problems with this model is that you can get a short in the tray 3 and 4 wiring looms. To make sure this isn't your issue, check out ICP11 - 14 to see if they are open or closed circuit. If they are open, then you have a short in one of the trays.
    If that is the case, then look through previous threads to find the fix that I have posted.
    • YouthAttack
      • Mar 2010
      • 37
      i currently have the problem you mentioned except i was having problems with tray 4. i swapped tray 3 to 4 and now the machine is frozen at the space theme which is after the hour glass. i tried looking everywhere on this forum for the fix but i wasnt able to find anything. can you tell me what the solution is?
      • remati
        • 149
        For copy CF ..you must delete de old files on the old card ----DON`T FORMAT IT ----
        • jackson007
          • Jul 2010
          • 114
          cf to cf copy ok.u have to rewrite nvram not firmware
          • TheOwl
            • Nov 2008
            • 1732
            May I ask how you re-rite the NVRAM?
            I didn't think that the NVRAM could be written to normally without the machine doing the work or reprogramming the chip manually.
            • peter
              • 15
              There is a Disk tool program to write B601/751 cards back to factory state available from KM
              Regards
              Thanks guys,
              • TheOwl
                • Nov 2008
                • 1732
                That is the CF card, not the NVRAM. I have both the disk tools from Konica Minolta, but nothing to rewrite the NVRAM.
                • peter
                  • 15
                  I have had plenty B601/751 s hanging on hour glass , rewriting CF card with disktool always fixes the problem, Never had problems with NVRAM and i doubt there is any proceedure to reset the NVRAM
                  • Eugene74
                    • 70
                    Re: Bizhub 601 Copy Firmware from CF to Other CF
                    Hi all,
                    I have had a problem similar to what you describe. I did write the software onto the CF card with the disk tool, but when I installed the card back into the machine, the machine rebooted every time. The hour glass comes up, displays for about a second and then the screen goes blank, and the process repeats the whole time. Is it normal because this happend for about a minute and I have switched the machine off ad removed the card to try and rewrite it again.
                    I can't find any documentation on what must happen if your wrote the software to factory default.
                    What I also saw was that on a operational CF card there are about 90 files (including directories), where as if you have done the factory default there is about 10 Files (including directories).
                    And I only deleted the old files, NEVER formated the card.
                    Any info would be appreciated.
                    Thanx
                    Eugene
                    • TheOwl
                      • Nov 2008
                      • 1732
                      It could be that your CF card is corrupt and needs to be replaced.
