C 252 After switch on the machine display getting black
  • Karelkat
    • Jul 2010
    • 18
    #16
    Originally posted by seltan
    After switch on the machine display getting black so our service person said MFP board to be replaced,
    Now i need a any expert solution regarding this issue I am also engineer so if any body says any testing method of MFP board I will do,Please help me.
    Have you done a nvram reset?
    If I understand your situation You have removed some boards and sent them to office and now they not working properly from 1 problem to bigger problem!
    Just maybe nvram has been corrupted in the process of shipping.
    • Karelkat
      • Jul 2010
      • 18
      #17
      i will try and get back you,thanks for your ideas.
      sir may i know that u r from whr?
      HI Seltan
      I'm from South Africa
      FIFA 2010 houst.
      • seltan
        • 24
        #18
        C 252
        Originally posted by Stirton.M
        Like I said, check all the connections and inspect everything. Basic troubleshooting.
        If this does not get you a running machine, you need to replace that board unfortunately.
        Sir,
        Today i have installed that mfp and mechanical pwb in that machine and i find out some output from that machine so i wish to share to get solution from you,I hope that you are only person able to given solution,Unlikely if not please discuss your higher people and get back me because you are working in konicaminolta there may be possibility to get solution.
        1.After the installation of pwb there is nothing happen but START button lights up like Orange color (display not ON,no sand watch etc..)
        2.In the MFP pwb there are lot of test points(TP) and checked all the tp with multimeter and measured correct voltage according to the mentioned in boards(so i confirmed there is no voltage break)
        3.Unfortunately in the some of TP there were no output measured (voltage also not mentioned in the boards but the same condition another TP showing out puts like 1.25v etc) .
        4.For your reference I given the TP details that TP 005-No output,TP 714-No out put,TP 802-No output(rest of TP showing some values)
        5.Also switched ON and OFF the some switches located in MFP pwb that SW 700 and SW 600.
        THIS WAS MY OBSERVATION AND TEST , I REQUEST YOU THAT PROVIDE ME SOME TECHNICAL DETAILS AND SOLUTION TO SORT OUT PROBLEM AND CONFIRM ME WHAT OUTPUT WILL COME IN THAT TP ANN WHAT IS THE RESPONSIBLE PART MAY FAULT.
        6.my superior said that NVRAM working in good condition with other machine.
        • seltan
          • 24
          #19
          i need solution
          • remati
            • 149
            #20
            helllo friend...
            -I have had 3 times that problem
            ...First time- was the "" M board"" in the side of the machne...
            ...Second time- was the "NV ram " I only used the "RAM recovery FW" , and its working hard...
            ...last time was ...can you believe the panel board and I changed all the panel unit...
            ....But....
            tray look the conectors of the control panel " flat cable "
            best regards
            • remati
              • 149
              #21
              see this information too..
              Description
              No display on the control panel.
              Solution
              CAUSE: No display on the control panel. Possible bad connection .
              SOLUTION:
              1. Re-flash the copier with current firmware.
              2. Re-seat all connectors on the PSB-MFP or PWB-PRCB.
              3. Replacethe PWB-MFP or PWB-PRCB.
              Model Description Part Number
              C252PWB-MFP 4038-2414-01
              C300/C352PWB-PRCB 9J06-0121-06
              • remati
                • 149
                #22
                Solution ID
                TAUS0700530EN* Solution Usage
                Description
                LCD goes out after about 10 seconds.
                Solution
                CAUSE:
                PWB-MFP not working properly.
                SOLUTION:
                1. Reseat all the connectors on the PWB-MFP.
                2. Flash the copier with current firmware.
                3. Replace PWB-MFP.
                Model Part Number
                C250 PWB-MFP 4038012106
                C300 Printer Control Board 9J06012106
                C352 Printer Control Board 9J06012106
