C360 Server Connection Error - Exchange 2010
+ More Options
Posts
  • swt
    • Jul 2010
    • 44
    Hello,
    we've just received delivery of a new C360 but have been unable to get scan to email to work. A new connector has been created on our Exchange 2010 server but we keep getting 'Server Connection Error' (error code 57) when testing scan to email (direct input to a destination within our domain).
    The ldap connection tests successfully so we're on the network ok (I can connect via PageScope) but I've tried various settings to get scan to email to work - all to no avail - and the trouble is: I've been looking/trying so many options my brain's turned to soup and I can't see the wood for the trees anymore!
    Do you know if it should work ok with Exchange 2010?
    Thanks,
    Michael
  • BIG PAPA
    Da Boss
    • 234
    Havent tired with 2010 exchange yet. My area tends to be alittle late behind the times. Do have all the domain info prgramed in? SMTP info? Admin email info?
    sigpic
    • swt
      • Jul 2010
      • 44
      Given the number of options/locations I can't say for sure that I've got the correct info in the right places, especially as we have changed things a number of times (as may be obvious from the settings below).
      System Settings - email address is domain admin address (until we can get it working at least).
      Security/SSL - is set to None.
      General Settings - user authentication is Off.
      TCP/IP - is on with a static IP, default gateway is the IP of the exchange server connector, IPv6 was On (just set to Off), Primary DNS is our main DNS server.
      LDAP - 'Check Connection' completes ok.
      Email TX - SMTP server address is the address of our exchange 2010 server, using SMTP over SSL, with port 26 to match server connector, SSL port number is 50001, device mail address is administrator@ourdomain, SMTP authentication is On using administrator details.
      Exchange 2010 Server - connector is set to receive mail from the Konica IP on port 26. Authentication is set to TLS.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        though not directly related to your machine or exchange 2010, the attached document may be of value in finding what your problem may be.
        In this case, Exchange 2007.
        Good luck.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • TheOwl
          • Nov 2008
          • 1732
          On the copier under your Email TX settings, try changing the encryption mode to 'Start over TLS'.
          Are you 100% that you are using port 26 for SMTP as port 25 is the default for Exchange? Another thing would be to try using the IP address instead of the Host name of your sever.
          • swt
            • Jul 2010
            • 44
            Apologies for the delay in getting back. It's finally working but I don't know how exactly. We reset the settings as below and it worked first time (I assume we just hadn't tried the correct combination).
            Changed the port back to 25, set Use SSL/TLS to off, unchecked SMTP authentication and set Default Gateway to our dns server.
            Stirton.M - the settings on our connector are different to those in the document but that would have been my next step.
            Thanks for the suggestions.
            Michael
