Magenta Bacground while copying Bizhub C 352
  • KMM
    • 9
    [Misc] Magenta Bacground while copying Bizhub C 352
    Hi,
    while copying colour copies magenta background comes on copies as well as even only when machine is made on or even when the transfer belt is clean and when the machine runs again the transfer belt is full with magents toner.
    Can anyone please help and say where the problem lies.
    Thanks.
  • seltan
    • 24
    Megenta unit corona unit problem so open the unit and clean complete unit and put it back otherwise to confirm the problem just replace the top unit of the imaging unit with yellow unit,ok all the best
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Check to ensure the image unit is seated properly inside. Check the bias connector tabs to to make sure they are not damaged. Check them for continuity to their termination points. Check the HV connections along with the board. Swap the HV board.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • PeterG
        • Jul 2008
        • 177
        Swap laser units M with say C. I had this problem recently. Turned out to be bad connectors on MFP board. Could also be bad connectors on laser or laser interface board.
