Bizhub 160, W7 64 drivers
  • Hansoon
    • Sep 2007
    • 3391
    Are there any drivers which could be used for the Bizhub 160 in a W7 / 64 environment?
    Any workarounds if no driver available?
    Hans
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I do not see a windows 7 64 bit driver or the plans for one. I would try the vista universal 64 bit and add it manually.
    • aesthetics1
      • May 2010
      • 148
      Try a generic PCL driver. HP Laserjet 4 works usually. I think you can try the HP Laserjet 4000 also in Windows 7 if the 4 isn't available.
      • Eugene74
        • 70
        Try looking for the driver here.
        Multifunctional Systems Black and White - Copier / Print Systems | KONICA MINOLTA
        • Hansoon
          • Sep 2007
          • 3391
          Thanks, I have looked there before but no W7 64 GDI drivers.
          Customer is not amused.....
          Hans
          • aesthetics1
            • May 2010
            • 148
            Have you tried this as suggested months ago?
            • tech51
              • 846
              Got same problem, so far no HP or KM driver will work. Will keep digging though, if I find anything I`ll report back
              • Hansoon
                • Sep 2007
                • 3391
                How can a PCL driver work with a GDI only printer?
                Hans
                • tech51
                  • 846
                  Found a print driver on the onyx portal (KM USA) says its for Win7 but sadly it doesnt appear to work. Never mind onwards and upwards.
                  • jma676
                    Expert Tech
                    • Mar 2009
                    • 323
                    Hans
                    Maybe you can try a Bizhub 163 !!!... or modify the drv yourself , if you know...and you have tools to edit drv.
                    • Hansoon
                      • Sep 2007
                      • 3391
                      The Bizhub 163 is a totally different machine than the Bizhub 160 series.
                      Why should I invest time modifying a driver for a crappy machine costing 400 USD sold by a company caring sh#t about after sales support for a cheapo customer choosing this turd of a machine.....?
                      Hans
                      • jma676
                        Expert Tech
                        • Mar 2009
                        • 323
                        OK, just mention the Bizhub 163, because it supports W7 64bit.
                        and with respect to modifying the drv, maybe it is a way out, I have adapted driver of different models to get some purposes, but of course within the same OS, but rather we are talking about adapt applications x86 (32bit) to 64bit you should look for there.
                        'll Let you know if I know something
                        • mascan42
                          • Oct 2008
                          • 485
                          I had this same problem a while back (Vista 64, not Win7 64). The Bizhub 181 drivers work just fine, since it's essentially the same print controller.
                          *Edit* Since you're in Europe, the Bizhub 163 is your equivalent of the 181.
