Minolta EP6000 error code C0070
  • mysticus
    • Feb 2007
    • 21
    Have checked to make sure the toner bottle is in correctly. Can this be reset? Any solutions...am listening. Thanks
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    i am not to sure about the reset opening it up and closing it should work. i have personally not worked on to many 6000. but what i would check is sorry if i am not politically correct on parts. so check where the toner motor is there is a white plastic piece in the toner section that the motor goes into make sure that there is nothin wrong with it. it could stop the toner from turning and that could cause the code
    • Mark B
      • Jul 2006
      • 153
      Reset by opening and closing front door. Motor could be bad or home position sensor could be dirty.
      • Luther
        • May 2006
        • 682
        Also make sure it is not a generic toner, have had problems in the past with generic toner bottles, also if you have had the back cover off the machine make sure the sensor on the bottom left hand side is actuated.good luck
        • mysticus
          • Feb 2007
          • 21
          Thanks for all the imput
          will post the outcome as soon as I get back to the unit
