Scanning on Bizhub 163 leaves machine hanging.
  • johanve
    • Jun 2025
    [Misc] Scanning on Bizhub 163 leaves machine hanging.
    When I scan to ftp on the Bizhub 163, the scanned file goes through to the folder but the machine itself still displays SCAN: Sending. It wont scan or print anything until it is switched off/on.
    Please help.
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Have you checked your firmware levels?
    Parts: Its what your copier craves!
    • RRodgers
      • Jun 2009
      • 1947
      Yeah, be sure the firmware is up too par and be sure that all your network info is put in properly. ie DNS Gateway and all that jazz.
      • Karelkat
        • Jul 2010
        • 18
        Please help.
        Hi if the FW does not help. unplug the df try scanning of the glass. I have had the Df causing simulear problems. Think it was the cable from df to machine.
        • johanve
          All firmware is up to date Machine, IC and fax. took a friends laptop with Windows 7 on and it suddenly started working. So I think that the problem could be with my laptop but it has have the same fault as my customers laptop. Any ideas???????????????
