bizhub c552 Print is brighter at the edges of paper
  • odb
    • Jul 2025
    SKMBT_C552100708133&.jpgKonica Minolta bizhub c552 Print is brighter when mix cyan and magenta, yellow and magenta or cyan and yellow at the edges of paper. The pritner is new only 860 prints.
  • minimerlin
    • 851
    Originally posted by odb
    [ATTACH=CONFIG]5289[/ATTACH]Konica Minolta bizhub c552 Print is brighter when mix cyan and magenta, yellow and magenta or cyan and yellow at the edges of paper. The pritner is new only 860 prints.
    Not sure what you mean and are showing on the jpeg..could you expand?
    Please do not PM me without asking first.
    • mojorolla
      The Wolf
      • 2627
      Try running the gamma setup in service mode. I had one real strong on Magenta, ran the gamma adjustment and colors returned to normal.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        It looks to me like the process colours are not quite mixing as they should. Its hard to tell on that image for certain.
        I suspect they are printing to heavy paper stock and not adjusting the trays to compensate.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • odb
          This is printed on plain paper and and the difference in colors is shown on all types of paper. If you see a picture where I show a little more detail what the problem is
          I apologize for the spelling mistake
          • Stirton.M
            • Oct 2009
            • 1804
            You could try tweaking the transfer voltages a little, reduce second transfer. The reproduced images appear to be blasting, which would suggest the transfer voltages are too high. It might even be an evironmental problem, such as too much humidity or lack of sufficient. What are the humidity sensors reading at?
            Firmware could also contribute to this, ensure the latest firmware is loaded.
            ---Groucho Marx
            • Karelkat
              • Jul 2010
              • 18
              Replace laser unit. We had brand new C652 do the same thing.
