KonicaMinolta Bizhub-350 with Faxkit FK-503, dial problems.
  • Hansoon
    • Sep 2007
    • 3391
    Installed a FK-503 faxkit in a BH350. Machine dials a number but somehow the PBX can't handle the dialing. During dialing it gives suddenly the busy tone. However when using the On-Hook-Dial dialing goes through and everything is OK.
    Question: Could it be that automatic dialing goes too "fast" for the PBX? Can this somewhere be adjusted in the softswitch settings?
    Hans
  • Karelkat
    • Jul 2010
    • 18
    Try soft swich 512 bit 7 0
    • RRodgers
      • Jun 2009
      • 1947
      Sure it's in US and not JP? I see that A LOT!
      • Hansoon
        • Sep 2007
        • 3391
        Dial tone is present after 0-PAUSE so that seems OK. The busy tone is not coming directly but after 3-4 of the 6 digits to dial.
        Its working manually when dialing with the ON-Hook feature, but not when setting the original and than entering the tel. number. In that case you can hear in the speaker that it obtains a proper dial tone but within the following dialing sequence it gives suddenly the occupied beeps.
        Huh?? Its in Germany and the machine is set to the proper region.
        Hans
        • Karelkat
          • Jul 2010
          • 18
          soft switch 512 bit 7=0
          • RRodgers
            • Jun 2009
            • 1947
            Hans
            Sorry, thought you were in the US.
