C3906 bizhub pro 950
  • aleksander
    • 378
    Hi all,
    I have problem with bizhub 950. C3906 shown 3 times a week. the trouble code related with TH 4 and I've already replace it, but still shown. I tried DipSW3 bit 1, it works for 3 days and then the evil code occur again.
    Any idea? thank you.
  • aleksander
    • 378
    Any Idea for C3906 in bizhub pro 950? Please help. Very urgent.
    Thank you.
    • Gerg?
      • Jul 2008
      • 67
      CAUSE: Improper ventilation of cooling fan Cooling Fan/1 (FM1).
      SOLUTION: Remove the rear cover and run 50 or more sheets of 12x18 paper. If the error does not return, verify that Cooling Fan/1 (p/n 55FA 8052 1) is properly aligned with the hole in the rear cover (p/n A0G6 1612 00).
      SPECIAL NOTE: Solution contribution by Gary Scimeca, Production Print/SSD
      • aleksander
        • 378
        Cooling Fan? no. That's normal. The problem is, C3906 occured at least 3 times a week. C3906 related with TH4 and I already replaced it but the evil code still shown.
        Any other solution?
        • RRodgers
          • Jun 2009
          • 1947
          Thank you.
          I've seen issue's were the manual says it's the lower heat tube when in FACT it's a problem with the upper heat tube. Be sure to check the other one.
          HTH
          • remati
            • 149
            ...the thermistor problems ,are the codes SC36-XX......
            • remati
              • 149
              ...and if the code is the SC36-06
              SC36-06 every few days.
              CAUSE: Fuser parts require replacement.
              SOLUTION: Replace the following parts:
              26AA53150 (x2) - heat sleeve
              26AA53160 (x2) - bearing
              56GAR7100 - cleaning sheet
              55VA53070 - auxiliary roller
              SPECIAL NOTE: Solution contribution by Jim Frost, Image Business Solutions
              • aleksander
                • 378
                HTH
                RRodgers, could you describe your explanation? I tried to replace TH1, TH2, TH3, TH4 and finally I replace the Fusing Unit. But next day, C3906 occured again. I don't know what's going on with this one.
                Thank you RRodgers. I'm waiting for your information.
                • aleksander
                  • 378
                  I think I wrote C3906 NOT SC3606.
                  • RRodgers
                    • Jun 2009
                    • 1947
                    So is it 39 or 36?
                    • aleksander
                      • 378
                      So is it 39 or 36?
                      Of course C3906. I've never wrote 36**.
                      Any solution?
                      • remati
                        • 149
                        ok ...I`m so sory I looked for the Biz pro 920 manual
                        -C3906 ..if the machine have intermitent codes...
                        it may have problems with de connector (fuser unit to the machine)or the lamp L3...
                        • aleksander
                          • 378
                          OK, now working properly. Changing the Fixing Unit, Reset the fusing counter and now it works again. I hope no more C3906 in the future. Thank you guys.
