C451 double images
    • 30551
    C451 double images
    not the black image unit any other suggestions?
    shifted 1 inch to the top of doc's all colors , print and copy also internal prints.
    It looks digital like one of the polygon mirrors.
  • mo0651
    • 1054
    we have a lot of suggestions, but it would probably help YOU quicker with more info. A sample of it might even help. Smearing! How far apart are the images when they repeat? doing it on all 4 colors?
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      if you make some copies on the black there are no ghost images? did you try to clean the ITB(transfer belt)?
        • 30551
        Posted an update with sample image
        • Johnny_B500
          • Mar 2007
          • 24
          Did you ever resolve this? I'm curious to what ended up causing your issue.
          • Kmdurrin
            Copy/Print/Network Tech
            • Dec 2008
            • 132
            Looks like the machine is in envelope mode. That... or you have a bad transfer belt or transfer roller.
            Parts: Its what your copier craves!
              • 30551
              turn out to be MFP board
              seems they had some bad ones
