Bizhub pro c500
  • tmanamore
    • Sep 2009
    • 74
    [Misc] Bizhub pro c500
    My Bizhub Pro c500 reads "No Toner". I shake the bottle and it goes away for about 23 or 4 copies. What could be causing this and how can I fix it?
  • HORSE
    • Mar 2008
    • 186
    I would just put a new bottle of toner rather than just shake the empty one.
    Laughing......
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Man, your sense of humour is astonishing.... :P
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • HORSE
        • Mar 2008
        • 186
        What makes you think I was joking?
        Laughing......
        • Stirton.M
          • Oct 2009
          • 1804
          stating the obvious is what I mean.....I was thinking along the same lines but you beat me to it....heh
          ---Groucho Marx
          • HORSE
            • Mar 2008
            • 186
            Yeah I know what you mean about stating the obvious..... some of the dribble people post on these threads is nothing short of scandalous.
            This has to be my favourite thread/post by a member called 21043 http://www.copytechnet.com/forums/ko...html#post69708 what a clown.
            Imagine me suggesting to Japan that they need to supply an electric tea pot with every machine.
            Laughing......
            • tmanamore
              • Sep 2009
              • 74
              Joking
              Guys, I ask for some help and I get jokes. Of course I did the obvious. Now can we PLEASE stop joking and if you can help, please do so.
              • tmanamore
                • Sep 2009
                • 74
                Horse,
                Of course i put a new bottle in. I am a technician needing assistance and not an end user. Now can you please help?
                • HORSE
                  • Mar 2008
                  • 186
                  It would have helped if you had mentioned that you replaced the bottle in your 1st post as it's a pretty important factor, ok what colour of toner is saying it's empty? Does it just say one colour is empty and if so is it the same one everytime?
                  Laughing......
                  • Stirton.M
                    • Oct 2009
                    • 1804
                    I agree with Horse. It was an important thing to know. It helps if you tell us everything you did try so we know and can go on from there.... from a TSB
                    Solution ID TAUS0640745EN* Solution Usage 0
                    Description
                    PLEASE ADD TONER Y/M/C/K. message displayed while making copies.
                    Solution
                    CAUSE: Failed TSDB (toner supply driver board).
                    SOLUTION: Replace the TSDB (p/n 65AA-9060).
                    ---Groucho Marx
                    • HORSE
                      • Mar 2008
                      • 186
                      Description
                      Solution
                      Thanks Mike you just stirred something in my mind about a C500 calling Y/M/C/K.
                      Before I would jump in with TSDB I would be checking the action of the toner supply door, there are actually 2 switches for that little toner door TONER SUPPLY INTERLOCK (MS2) and TONER SUPPLY DOOR OPEN/CLOSE SENSOR (PS54). see Picture attached
                      The PS54 .... Photo Sensor switch is the logic switch (5V) tells the machine the toner door is closed, the MS2 switch is the mechanical interlock for the 24V to run the toner motors.
                      If that micro-switch MS2 is not making none of your toner motors will work and the machine will run dry and call toner. Check the toner door is hanging straight and that the interlock actuator is not bent or broken off (obvious when you now know what to look for) If not I would be checking the operation of MS2 in I/O mode and open and close the door normally and see if the input changes.
                      also try taking the front cover off and manually cheating the switches and running the machine... a badly fitted front cover could also prevent the door from actuating the interlock.
                      I have had this fault 1st hand a few years back.
                      Laughing......
                      • costel fasola
                        • Jun 2010
                        • 69
                        check in 47 mode 1-3, 1-6 , 1-9, 1-12 if toner botle is spining.
                        • tmanamore
                          • Sep 2009
                          • 74
                          Re: Bizhub pro c500
                          OK. I've checked and found that the yellow toner bottle clutch is not engaging. I swapped the clutch with another color to see if it worked and it did. Seems like the clutch is not being told to turn on when I checked in the 47 mode. Where should I check now?
                          • tmanamore
                            • Sep 2009
                            • 74
                            Re: Bizhub pro c500
                            Does the Toner Supply Driver Board as last posted feed the toner bottle clutches? If so, where could I start looking for one?
                            • JustManuals
                              • Jan 2006
                              • 9838
                              Re: Bizhub pro c500
                              Paul@justmanuals.com
