konica minolta 7085
  • naroeurn
    • Jul 2025
    konica minolta 7085
    Code SC21-01 show when I open mashin The copy can not use.
    Pls.help
    Thanks.
  • shawn Xia
    Xerox & Kinolta
    • Oct 2009
    • 24
    Pls.help
    Thanks.
    maybe there is something wrong on the charging unit.check two position sensors on the charging unit.
    MSN:matchdg@hotmail.com
    Xerox & Konica Minolta Tech
    • jbauer@abcvpr.com
      • Nov 2009
      • 21
      sc21-01
      check the drum unit area for paper or scraps of paper
      • costel fasola
        • Jun 2010
        • 69
        F21-01
        check position of charging wire cleaning pad limit.Chect on excess over M23 (charger cleaning).
        estimated abnormal parts: M23 (charger cleaning) DCDC (DC drive board)
        PRCB (printer control board) ps 41 (charging wire cleaning pad HP)
        ps 42 (charging wire cleaning pad limit) Breakong of hamess conector. For ignore F21-01 in 2-5 mode dip sw 3-3 set 1 and dip sw 3-4 set 1. be sure if charging wire pad is in home position.
        • RRodgers
          • Jun 2009
          • 1947
          Originally posted by costel fasola
          F21-01
          I use to just shut corona cleaning off. Never had the code cuz it never cleaned um.
          • mrwho
            Major Asshole!
            • 4299
            Pls.help
            Thanks.
            So, how did it turn out? Did you manage to solve your problem?
            Mascan42
            Ibid
