konicaminolta8020 not stsarting
  • khurram
    • Jul 2025
    HI, I HAVE MINOLTAkhurramshehzad_kps@hotmail.com 8020 WHICH IS NO STARTING.ONLY THE START KEY IS GETTING RED ELSE NOTHING SHOWING ON THE PANEL PLEASE SORT MY PROBLEM AS SOON AS POSSIBLE
  • NIKIL.KP
    • Jul 2010
    • 30
    sir,May be the machines firmware got corrupted,please rewrite the firmware and see.
    • khurram
      thanks for your suggestion nikilcan you tell me how to REWRITE THE FIRM WARE.And one more thing i had tried to change the power supply board but the result was same machine did not start
      • NIKIL.KP
        • Jul 2010
        • 30
        so, problem is not with your powersupply,but i am sorry to say i dont have manuals,but try to get service manual and the firmware will be downloaded from km tech site which is available 4 registered users which i am not.
        NIKIL
        • RRodgers
          • Jun 2009
          • 1947
          I can send ya the firmware, but ya need the special card and software to write it to the machine. So... firmware will probably be useless too you.
          • khurram
            thanks a lot u guys i don't need the firmware, because the machine is ok the problem was CABLE. It was damaged and after checking each n every thing in the last i found.THANKS TO ALL MIGHTY ALLAH WHO SOLVED MY PROBLEM WHICH NO BODY ELSE COULD DO.TAKE CARE PEOPLE.
