Service mode access for NEC IT3530D (Bizhub 350)
  • SAR
    • Jul 2009
    • 203
    We had someone trade in this NEC machine and it's in good working order. We don't want to put it in the field, since it's not a KonicaMinolta, but would like to hook it up as an in house printer for our warehouse.
    My question is, how do you access the service modes on the NEC machines? the admin mode is the same as KonicaMinolta models, but I can't get into the service modes.
    Thanks.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    utility
    meter count
    stop
    zero zero
    stop
    zero one
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • SAR
      • Jul 2009
      • 203
      Thanks for the reply, but that's the access method for the Bizhubs, it won't work on the NEC copiers.
      The NEC machines are re-labeled KonicaMinoltas, but have some differences.
      • Pinoy_Tech
        • Feb 2010
        • 47
        If that is Bizhub 350, it should somewhat similar steps on entering tech rep mode. The procedure above had missed one step, nothing will lose if you try it again; (utility>details>stop>0>0>stop>0>1).
        Hope this help ...
        • racosta
          • 53
          For the NEC models press access, account, press * 4 times. The start button will start to flash. Then press utility, user management, then service mode. To exit shut machine off. Or you can try this way also. Utility, access, press * 4 times, utility, utility, manitance, then service mode. Hope one of these works for you.
          • 907tec
            • 434
            We had one NEC re-branded biz 250 that had some craziness required to access service modes. IIRC, there were two separate tech modes requiring two separate methods of entry. The most helpful of the two tech modes (most reminiscent of the KM version) required dialing a fax number followed by a few keypresses. Something like dialing 1-9-1-9-1-9-1-9-1-9-1-9-1-9-1-9-1-9-1-9 (1-9, ten times) as a fax number, then asterisk and reset. I believe the other mode was entered by pressing "Access" then entering four asterisks, after which a new tech mode will appear under admin mode. I remember it taking me a few tries, so don't give up too quick.
            • SAR
              • Jul 2009
              • 203
              Thanks for the replies everyone. Racosta, the first method you mentioned got me right in.
