Bizhub 1050 touch screen isue
  • Holesaletech27
    • Jul 2009
    • 101
    The touch screen is in-op on this machine. I just read a thread on the C350/C450 with the same issue. I'm going to see if that fix applies to this model as well. Any other suggestions? I could use a part number and price for a replacement as well if anyone has that info...
  • freixi
    • May 2009
    • 53
    What is the problem of the machine?
    freixi
    • Holesaletech27
      • Jul 2009
      • 101
      The touch screen doesn't respond.
      • freixi
        • May 2009
        • 53
        So is a EP 1050? or a bizhub pro 1050?
        • ineo+6501
          • Mar 2010
          • 262
          Part number for the touch glass: A0G6:M755:00 = Ope.Unit Touch Panel
          Your local dealer will be able to price it for you.
          From a TAD on CSES:
          [Product Name] bizhub PRO 1050
          bizhub PRO 1050e
          bizhub PRO 1050eP
          bizhub PRO 1050P
          DEVELOP 1050
          generic_1050
          [Option]
          [Subject] After replacing the NVRAM, the touch panel does not function. [Description]
          [Solution]
          CAUSE: The touch panel adjustment must be performed.
          SOLUTION: Perform the following procedure to perform the touch panel adjustment:
          1. Press the [Utility/Counter] key on the control panel.
          2. Press the [5] key (hard key) on the control panel to select the "Touch Panel Adjustment".
          3. Follow the instructions on the display to perform the adjustment.
          SPECIAL NOTE: Solution contribution by Ian Lynch, Production Print/SSD
          [Attached Files] [Rev. Memo] Corrected procedure for touch panel adjustment (not in service mode)-irl
          [Problem code1] Main body control failure [Problem code2] R06:Main body lock up during operation
          • ineo+6501
            • Mar 2010
            • 262
            Ooops part number should be: A0G6-M755-00 = Ope.Unit Touch Panel
            • Holesaletech27
              • Jul 2009
              • 101
              I';s a Bizhub Pro 1050. Thanks for the pointers and info. I'll give it a go and try to get a price.
              • freixi
                • May 2009
                • 53
                Thank ineo. that's it.
