konica minolta 1080 copies are black... help!
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    the customer said that she was copying about 20 pages and all of a sudden the copies started to come out dark. any help?? i dont know if its the scanner or what, is there a way to get internal reports from the machine? any help is appreciated thanks in advance.
  • albasoul06
    well...... we are not GOD
    so better you take a look first and then ask us again
    but stop fixing machines by phone
    • Cantechman
      • Nov 2008
      • 228
      Is it dark or black? That could be 2 totally different problems.
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        hello can you see if the lamp exposition light in if you started one copy ?
        BEST TECHNICIAN . NICE PEOPLE .
        • RRodgers
          • Jun 2009
          • 1947
          Yeah, what they said.
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            course
            • Hansoon
              • Sep 2007
              • 3391
              If "dark" the exposure lamp or lamp regulator could be shot. If real black likely the cleaning blade failed.
              Hans
              • brent
                • Nov 2008
                • 1214
                my bet is the high voltage unit. I have had this pure black copies.. hv. I have noticed that these machines work great for about 14 to 15 years. once the hv unit goes out. I have had a hell of a time fixing them..
                • gerryhuerta
                  AccService
                  • Jul 2009
                  • 198
                  sorry for the extremly late reply, i still have this problem i just hadn't worked on it for a while. The copies are dark and not black, the image that was scanned can bearly be made out, due to the toner all over the page. I tried another drum unit that is in known working condition and i get the same results. If i stop the page in the middle of the drum, the drum has toner all over it with the scanned image faintly appearing on there, exactly as its coming out on the pther pages. As for the lamp being shot, I think the lamp is still good.
                  • Hansoon
                    • Sep 2007
                    • 3391
                    Why?
                    Hans
                    • brent
                      • Nov 2008
                      • 1214
                      do you have access to another hv unit? I doubt minolta sells them anymore. the machine has been discontinued for quite some time. you think the exposure lamp is good. tell us. with the lid open hit the print button does it illuminate? my bet is still the hv unit. I have had too many of them go out. I have also tried to replace the whole dv unit. thinking that would fix it. it rarely does...
                      let us know
                      brent
                      • eg101
                        • Jan 2005
                        • 131
                        Try another transfer/seperator corona unit
                        • minoltaed
                          • Aug 2009
                          • 45
                          Try hv unit I have replaced many on this machine.
                          • gerryhuerta
                            AccService
                            • Jul 2009
                            • 198
                            i dont have easy access to another hv unit and i think we just threw away a machine that crossed refrenced with this model. i will try anothe high voltage pcb and see what happens, thanks
                            • WildbillC
                              • Oct 2010
                              • 49
                              Also check the drum ground. If its the HV unit you should be able to tell by looking and
                              giving it the " smell " test....they dont die gracefully.
