Bizhub C252 - Replace Transfer belt message
  • AjitN
    • Mar 2009
    • 287
    [Misc] Bizhub C252 - Replace Transfer belt message
    Dear All
    I have one problem in hand, C252 is showing "Replace Transfer Belt Unit". Also life indicator displays that life is over and in life count it displays it has completed 1,20,048 cycles. Clearly Transfer belt unit needs replacement.
    I have replaced few Fuses with proper value ( 80ma ) which I have been using since last few years.
    Machine is not responding at all, I mean as soon as machine is put on, after Konica logo machine immediately displays replace Transfer Belt unit and does not even initializes which normally happens. Scince it is not initializing, fuse also does not blowup. I have checked the contacts, those are ok and +24V is present at both the ends.
    I have also tried with another old belt unit but same symptoms.
    Anybody faced this problem? Any other missedout actions? Please suggest.
    Thanks for all support
    Regards
    AjitN
  • moonwalker3778
    • Jun 2008
    • 87
    I think that fuse is not blown. u put 80ma quick blow fuses and try. in fuses there are several varieties. if u need those fuses mail me to sagarlasudhakar@yahoo.in.
