konica1216
  • cliffhangers
    • Feb 2010
    • 243
    konica1216
    greetings.I am haven problem with konica1216 it's displaying error code P26.please kindly help.thanks in advance.
  • BIG PAPA
    Da Boss
    • 234
    Description:
    P26 at power up.
    Solution:
    CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
    SOLUTION: To perform the L-detect adjustment procedure, perform the following:
    1. Power the copier OFF.
    2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
    3. Press the START/PRINT button.
    4. The number 51 flashes in the display for approximately 90 seconds.
    5. When the number 51 stops flashing, the adjustment is complete.
    6. Power the copier OFF/ON to exit the 47 mode.
    sigpic
    • cliffhangers
      • Feb 2010
      • 243
      Konica1216
      good evening or what ever time you see this.I have perform the L-detect procedure. I access the 47 mode and power the copier on while pressing the 4 and 7 keys,it show code 51 for 10 seconds and change to code F43 i power the copier off and on,it go back to P26 please kindly tell me what to do.thanks in advance.
      • cliffhangers
        • Feb 2010
        • 243
        Konica1216
