Konica c451 Open Cover Error on boot up
  • Oscar57
    • 79
    [Error Code] Konica c451 Open Cover Error on boot up
    Hi,
    Anybody every have a Konica c451 Open Cover Error on boot up. The Error states "the part indicated by the > arrow is open. Ensure that it is properly closed." Well there is no arrow pointing to any cover being open. Cannot print with this standing error. Any help would be appreciated. I also tried a hard reset.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Sometimes the machine can get stupid and needs a good firm kick...open and close every available door, cover on the machine one at a time. If it does not correct itself, call a service tech to look at the machine. It could need a firmware reflash, or there is some other issue not readily apparent from a user perspective.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • emujo
      • Jun 2009
      • 3009
      Disconnect the finisher and bridge unit and see if message goes away, if so trouble shoot for a bad MS that detects the open/closed position of the finisher shutter. Emujo
      • tcs04
        FORMER Techie
        • 1183
        Originally posted by Oscar57
        Hi,
        If it was a Ricoh, I would be looking at the laser safety circuit! I assume the K M is similar. Will look when I get time.
        • Oscar57
          • 79
          That was it. Thanks for your help!
          • Stirton.M
            • Oct 2009
            • 1804
            This is the second time I noticed you compare a ricoh to a Konica...last time I looked, there are no similarities between the two company lines, aside from both using similar technology to make a print using the toner method.
            ---Groucho Marx
            • tcs04
              FORMER Techie
              • 1183
              You would be surprised!
              • Stirton.M
                • Oct 2009
                • 1804
                Well, for one, there is no laser safety circuit.
                ---Groucho Marx
                • tcs04
                  FORMER Techie
                  • 1183
                  Next time I'm at a 451, I'll open the covers and check!!
                  • Stirton.M
                    • Oct 2009
                    • 1804
                    All switches (both optical and mechanical) related to the doors on any KM machine will trigger an open signal on the control panel, with a picture of the open part indicated on the control panel. And as such, ANY open door will shut down the print head, regardless. Previous generations, the print heads were separate for all four colours, and they employed a mechanical cover on the PH unit itself that closed when an IU was pulled out. That was the extent of the "safety" on that series. C451, the PH unit is an all in one design but also employs a mechanical cover when the IU is removed. Situations like the one above, are not typical of a properly running machine. Emujo's explanation illustrates that some areas internal can trigger this issue if the optical sensor is damaged or there is a board level problem.
                    ---Groucho Marx
