Konica1216
  • cliffhangers
    • Feb 2010
    • 242
    Konica1216
    Hi.with the ink unit it display p26.
    i remove the ink unit and power the copier on it still display p26.help.Thanks in advance.
  • deep
    • Jun 2008
    • 208
    You have to seek for a tech if you cannot solve the problem by yourself.
    Kenny
    • DCPS
      • Mar 2008
      • 116
      P26 at power up. SOLUTION ID: 142860
      SOLUTION: CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
      SOLUTION: To perform the L-detect adjustment procedure, perform the following:
      1. Power the copier OFF.
      2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
      3. Press the START/PRINT button.
      4. The number 51 flashes in the display for approximately 90 seconds.
      5. When the number 51 stops flashing, the adjustment is complete.
      6. Power the copier OFF/ON to exit the 47 mode.
