password
  • jackson007
    • Jul 2010
    • 114
    password
    service password c353
    sir,
    one of my costomer had called unothorised engineer for service of c350.he changed password of Admn & c.e.password .I could not abel to open it help me please .
  • jackson007
    • Jul 2010
    • 114
    help me sir
    • TheOwl
      • Nov 2008
      • 1732
      If what I read is correct and you are an authorised Konica Minolta Dealer / Repairer, then I would suggest that you call Konica Minolta as I believe that the passwords are on the NVRAM and that you might have to replace it. If I am right, then you will need to talk to Konica Minolta to get the NVRAM anyway as Konica Minolta Japan doesn't just willingly release NVRAM chips to everyone.
      If I read wrong and you are not an authorised Konica Minolta Dealer / Repairer, then I would suggest getting someone in to look at your machine or the same person that set the passwords in the first place.
      • jackson007
        • Jul 2010
        • 114
        we are authorised dealers for konica minolta nothing to worry i can get nv ram also.if solve ok.thanks.i will try.thank u sir
        • jotunn
          • 606
          So which machine is passworded? In bolded text there is C353, but later you wrote about C350... That's difference - in case of C353 (and if you are authorised dealer) you can remove password yourself, and you don't need to change NVRAM. In case of C350, you can't remove password yourself, but... that's another story ;P
