c350 hv1
  • jackson007
    • Jul 2010
    • 114
    c350 hv1
    sir
    one of our costomers machine c350 is showing C 0204 code.is it hv 1 problem.plz help me sir
  • ineo+6501
    • Mar 2010
    • 262
    C0204 Yellow PC Drum Charge Corona
    malfunction
    • jackson007
      • Jul 2010
      • 114
      what i have to do,clean the i u unit. or replease i u (but it is only25000 copies life)
      • ineo+6501
        • Mar 2010
        • 262
        Assuming this is a C350, you can attempt to clean the charge corona using the blue wand attached to the Yellow unit by pulling it in and out.
        Failing that, replace the whole unit with a new one if you are not a tech.
        • jackson007
          • Jul 2010
          • 114
          sir,
          i am a tech rep I can abel to open and nlean ,but what i have to cleanproperly.
          • ineo+6501
            • Mar 2010
            • 262
            2.6.23 C0204: Yellow PC Drum Charge Corona malfunction
            Relevant Electrical Parts
            Imaging Unit /Y
            High Voltage Unit/1 (HV1)
            Control Board (PWB-MC)
            Step Action
            WIRING DIAGRAM
            Control Signal
            Location
            (Electrical
            Component)
            1 Check the Imaging Unit contact and correct or
            clean as necessary.
            2 Check the HV1 contact and correct or clean as
            necessary.
            3 Change Imaging Unit. — —
            4 Change HV1. — —
            5 Change PWB-MC
            • jackson007
              • Jul 2010
              • 114
              [QUOTE=ineo+6501;158075]2.6.23 C0204: Yellow PC Drum Charge Corona malfunction
              Imaging Unit /Y
              I replaced imaging unit but it is showing same
              • mrwho
                Major Asshole!
                • 4299
                Before fiddling with the machine's boards and wiring, have you checked the contacts at the back of the machine to see if they're making proper contact with the IU?
                Mascan42
                Ibid
                • ineo+6501
                  • Mar 2010
                  • 262
                  Changing the imaging unit is the 3rd step in correcting this fault. The 1st and 2nd step need to be completed before changing the IU.
                  It is likely one of the contacts.
