bizhub c250 no on
  • alfpanasonic
    • Jan 2007
    • 73
    bizhub c250 no on
    When I bind bizhub c250 in main and to follow in sub-main the machine it always shows the hourglass and later it disconnect.
    Any information?
  • Bizhub
    • 147
    You nvram has failed.
    contact Konica-Minolta and get them to replace it. If that fails you could try the nvram recovery tool.
    Good luck
    • alfpanasonic
      • Jan 2007
      • 73
      Solved
      Problem solved, I executed firmaware and evrything is ok
