The issue is that if you change any settings within the driver properties to booklet or staple etc via the print dialogue within Indesign or Illustrator they are ignored and the driver outputs at default settings, if you change the driver defaults within the Win7 printers dialogue then the output changes!
Issue with Adobe CS3 and fiery drivers on a 64 bit Win 7 o/s
indesign and illustrator exhibit this issue but no other app within the CS3
also my test pc running same setup but 32bit version works fine.
also installed a Canon fiery driver and that showed same issue!
any ideas I am guessing its a rights issue within Indesign but not sure where?
