Konica 7145 printing code
  • ejaboneta
    • Aug 2025
    We just bought a used konica 7145. I downloaded and tried all the drivers from konica's website but whenever I print, the copier prints PS code. How can I fix this?
  • mrwho
    Major Asshole!
    • 4299
    PostScript is an option for the print controller, and your machine most likely doesn't have it.
    Try with PCL drivers.
    Mascan42
    Ibid
    • mrwho
      Major Asshole!
      • 4299
      PCL5e drivers - Download Result - Download Center | KONICA MINOLTA
      Mascan42
      Ibid
      • ejaboneta
        The copier does nothing when I use the PCL driver
        • RRodgers
          • Jun 2009
          • 1947
          Your machine probably has old firmware in it and will need to be flashed up to at least version 25.
          You are going to have to call a tech.
          • Konica_jr
            • Aug 2010
            • 25
            maybe you doesn't have on board IP432 !
            " French do it better " ^^
            • mrwho
              Major Asshole!
              • 4299
              If the machine spits out printed paper when he tries to print - even if it's unreadable - he must have an IP installed.
              Mascan42
              Ibid
              • ejaboneta
                So how is the firmware updated and where would the new firmware be found? Just curious as I'm guessing it's not something I could do myself?
                • mrwho
                  Major Asshole!
                  • 4299
                  Well, if you're the kind of guy that fixes his own car's crankshaft without being a trained mechanic, then you could do it yourself without being a trained tech. I can give you a list of stuff you'll need, but you need to get all the stuff (since it's a somewhat old machine it's not exactly very easy) AND, if you do manage to get all of it, you risk damaging the equipment if it's not done properly.
                  Mascan42
                  Ibid
                  • ejaboneta
                    I think I'm a do it my self kinda guy... Is there a way to check the firmware version? I found this on the web utility:
                    • RRodgers
                      • Jun 2009
                      • 1947
                      if you just wanna print and not worry about any options (ie duplex and use a certain tray) you can just use the HP Laserjet 4 driver (built into windows) and it will print all day long.
                      You'll need the ISW software and a computer (or laptop) with a parallel port to write the new firmware to the machine (oh.. you'll need the firmware as well) Mess it up and it's a brick.
                      I'm really starting to see a trend here, more and more people wanting firmware to update there machines. For un old box like this.. ya shouldn't do it. Ya mess it up and it's bye bye machine. Well... it is an old box and maybe that would force ya to get a new box or pay someone who know's what they are doing to come out and do it for ya.
                      And the (it seems to me) requests as of late for firmware from people that I honestly feel shouldn't have it is really starting to grow as of late. I don't mean to come down on ya ejaboneta, but... your post was convenient for me.
                      • ejaboneta
                        The hp driver did work. Thanks for the advice. However, I would still like to know how to update the firmware... where to get it and the software. And maybe even how to find the current firmware version. I followed some instructions that gave me the startup version 5.8.2... Is this it?
                        • RRodgers
                          • Jun 2009
                          • 1947
                          5.8.2 sounds like it's probably the print controller. Was that on a page that spit out a while after the machine was turned on?
                          Good luck on getting the software.
                          • mrwho
                            Major Asshole!
                            • 4299
                            Well, I'm temped to give him the necessary tools for updating the firmware - now that the machine is working, maybe he'll brick it and we get some good laughs.
                            Mascan42
                            Ibid
                            • Mercutio Norway
                              • 11
                              If I recall this right....
                              When printing to a 7145 I recall you had to enable the 'print to queue' and name this queue 'print'....
                              I might be wrong, but I do remember I had to do something like this on a PCL5 driver...
