konica1216
  • cliffhangers
    • Feb 2010
    • 243
    konica1216
    good day.I have 5 konica1216 but this time they are given me problems.the spanner was indicating i perform the PM and L.detect after performing the copier stop copy and was displaying P26 or F26.I did all i can it still display P27orF26,then i remove the memory bode from the other copier which was working and put it to the copier that was displaying P26orF26 and it worked.so please i one help to that code P26orF26 from the memory.please kindly help me or my customers will ran away.THANKS IN ADVANCE.
  • mrwho
    Major Asshole!
    • 4299
    DESCRIPTION: P26 at power up.
    CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
    SOLUTION: To perform the L-detect adjustment procedure, perform the following:
    1. Power the copier OFF.
    2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
    3. Press the START/PRINT button.
    4. The number 51 flashes in the display for approximately 90 seconds.
    5. When the number 51 stops flashing, the adjustment is complete.
    6. Power the copier OFF/ON to exit the 47 mode.
    Mascan42
    Ibid
    • mrwho
      Major Asshole!
      • 4299
      DESCRIPTION: F26 at power up or following the TDS adjustment (L-detect).
      CAUSE: Toner was added before performing L-detect during new machine setup. Refer to [[2223
      SOLUTION: To prevent F26 error codes, perform the following:
      1. Access the 47 mode (press the 4 and 7 keys simultaneously while powering the copier ON),
      output code 40 (approximately 3 minutes) to allow the excess toner in the TDS area to mix with the
      developer.
      2. If F26 reoccurs, replace the developer (PCUA 947226) and perform the L-detect adjustment
      again (47 mode, output code 51).
      Note: L-detect must be performed before adding toner at new machine setup or toner addition will
      occur during the adjustment, resulting in a F26 code.
      Mascan42
      Ibid
