bizhub 600 no display
  • acsolutions
    • Jun 2010
    • 519
    [Electrical] bizhub 600 no display
    Hello, not sure where to start my bh 600 has no display. the only thing I hear is fan noises and the main power LED is on, on the control panel.
  • Scijohn23
    • Sep 2009
    • 91
    I would start by checking the connections to the op panel and make sure that they are all seated firmly, then I would check out the power supply for any blown fuses, or anything that is obviously out of place or unusual.
    • mrwho
      Major Asshole!
      • 4299
      I had that twice - you could have either a firmware problem or a malfunctioning control board.
      First try to reflash the firmware. If you're unable, you can still take out the boards at the back of the machine and take out the CF cards on the boards. Then you need a another bh600 in working condition - you need to take its CF cards out too and copy the files from the GOOD CF cards onto the BAD CF cards. That one did the trick for me.
      Mascan42
      Ibid
      • Scijohn23
        • Sep 2009
        • 91
        Good answer mrwho,
        • mrwho
          Major Asshole!
          • 4299
          Thanks.
          Mascan42
          Ibid
