J92-01 on Konica minolta 1050
  • shawn Xia
    Xerox & Kinolta
    • Oct 2009
    • 25
    today we meet a big problem.When we print duplex more than one page,the first page has been outputed and the other pages are jamed in the convert roller(when the second page arrived,the roller didn't roll at all)
    then the copier show J92-01.but the sigle side print is no problem.the problem only happen in duplex mode
    I changed ADU DRIVE Board,but the problem isn't solved.I check the moter M12 and all the gear,roller,senser,they are ok.
    who can help me?
    MSN:matchdg@hotmail.com
    Xerox & Konica Minolta Tech
  • jma676
    Expert Tech
    • Mar 2009
    • 324
    Look at this example, in general these issues are very simple, try to look at the paper ticket, it is common to find small pieces of paper to stop the passage of paper, check all sensors in addition to the PS48-PS46 may have dirt this is also common to happen.
    • Chromatik
      • Aug 2010
      • 71
      OK, Something similar happens in the DI850/750
      • jma676
        Expert Tech
        • Mar 2009
        • 324
        good luck!!!!!!!
        • Chromatik
          • Aug 2010
          • 71
          Tanks!*
          • jma676
            Expert Tech
            • Mar 2009
            • 324
            if so these failures are similar in these models.
            • costel fasola
              • Jun 2010
              • 69
              Re: J92-01 on Konica minolta 1050
              i have similar problem (when duplexing) 92-01, 92-02, 93-01 but only at first page at job. he`s jam but if unblock he run`s to finish paper or next job.
              i change ADU unit (ALL unit)
              Any sugestion?
              • allan
                RTFM!!
                • 5459
                Ok on this model B601/750 and the like, there is mylar you need to replace or just remove on the u channel shaped bracket holding 2 driven rollers on the bottom of the ADU at the entrance leaving the fuser. These things fail like clockwork at around 350K it gets eaten thru by paper leaving edges for the paper to catch on.
                Whatever
                • costel fasola
                  • Jun 2010
                  • 69
                  Any sugestion?
                  PROBLEM ON BIZHUB1050
                  • costel fasola
                    • Jun 2010
                    • 69
                    any ideea ?
                    • methogod
                      • Dec 2008
                      • 915
                      On the 920/950 this happens when the exit sensor is dirty. you would think its where the jam says it would be, but 1st take off the finsiher, and duplex see if its codes...
                      if it does it the exit sensor if it doesnt then it the entrance sensor on the finisher.
                      1050 has tons of fixes and mods, make sure your machine is somewhat up to date.
                      also what is your meter at? high volume machines are notorious for having duplex only issues...
                      • emato
                        • Apr 2014
                        • 12
                        Take a look at what position paper stop. With jammed paper make a corresponding test from Service Mode - Machine condition for sensors, it can be dead. Also you may need to replace rollers, especially if machine print more than 10 millions copies without "6 millions TO".
                        • fntsy
                          • Aug 2008
                          • 26
                          Sorry to bring this topic back up, but the same jam code started to show up a 1050 I am servicing. I did change M12 and M15 motors. I did check all the paper sensors in the ADU and they are working.
                          There was no conclusion in this thread what might seem to be the problem.
                            dead thread please start your own 4 years dead
