Bizhub C253
  • JSC
    Gimp
    • Dec 2006
    • 618
    Bizhub C253
    I have a machine that came up with "the following operation can not be used...........scanner"
    After unpluging the copier and pluging back in it went away, only for it to come back after an hour!
    I have since updated the firmware, formated the hard drive,NV RAM reset, swaped ram. It only clears after the plug has been pulled. then will come back after a few hours.
    UK help desk have no idea.............anyone out there got any suggestions?
    The gene pool could use a little chlorine.
  • RRodgers
    • Jun 2009
    • 1947
    HDD?
    • Konica_jr
      • Aug 2010
      • 25
      Hi,
      did you have look at the exposure lamp drive unit ? Maybe the power cable of the lamp is out of is way !
      " French do it better " ^^
      • Emjay
        • Jul 2009
        • 42
        Does the doc feeder / scanner do anything?
        There is a surface mount fuse that can fail, dropping a particular supply rail to the doc feeder. If this has gone, the copier main body thinks the scanner isn't present.
        Think the fuse was rated at 2.0A from memory.
        • JSC
          Gimp
          • Dec 2006
          • 618
          Originally posted by RRodgers
          HDD?
          Have formated it, but I might change it to confirm.
          DF works, but the scanner does not,the lamp does not move or turn on when the df is lifted, until the the machine is unpluged and pluged back in, then it all works fine for a few hours.
          Originally posted by Konica_jr
          Hi,
          It all looks fine.
          • mo0651
            • 1054
            check the doc. feed open/close actuator. the plastic cover that surrounds it may be pushed up against it and it may stick down. We had one that was giving strange messages when that happened.
            • jma676
              Expert Tech
              • Mar 2009
              • 323
              Maybe!!!!!!!
              • B0265
                • Jan 2007
                • 718
                Have you checked the service call history?
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  I have checked and all working ok.
                  Originally posted by jma676
                  Maybe!!!!!!!
                  No error codes logged on machine,
                  The fault has not come back for a couple of days.....................so f***k knows!
