Authentication via barcodes? WTF!
  • mrwho
    Major Asshole!
    • 4299
    [Misc] Authentication via barcodes? WTF!
    We've got a customer with several KM machines. Apparently he uses barcodes as authentication in other areas of his business (silly, if you ask me - if I grab someone's card I just need to photocopy it in order to use it). Now he wants to use the same method in order to restric copying and printing.
    My question is: Is there any device that can be connected to recent KM machines that can read barcodes so the machine can accept the barcode content as passwords?
    Mascan42
    Ibid
  • Cantechman
    • Nov 2008
    • 226
    Nothing I am aware of that uses bar codes, there is the bio-metric scanning. You could get the Hecon keys at one time. Other than that I am only aware of the copy track features.
    • mrwho
      Major Asshole!
      • 4299
      Could it be even remotely possible to connect an USB barcode reader so the machine can recognize it? If a PC can recognize the biometric and card reader USB options, maybe the opposite can also be done?
      Mascan42
      Ibid
      • Cantechman
        • Nov 2008
        • 226
        What models are you asking about specifically? I can take a look on an individual basis to see but I doubt very much if it would work.
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          I've seen kiosk devices that scan barcodes for specific things. A good example here in Canada, related to the national lottery 6/49, many places where you buy the ticket, the ticket will have a custom barcode generated, which can be inserted into any reader at any retail store that sells lottery tickets, and scanned directly to tell you in an instant if you have a winner and what you won.
          I've seen magnetic card reader devices at some customers places, these are third party authentication machines plugged into the copier with one of the different "vendor" options set in CE mode. These devices are very proprietary, aside from the wire to the copier. All KM hardware has provision for coin op or similar authentication interface.
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
          • jma676
            Expert Tech
            • Mar 2009
            • 324
            Some types of authentication are already known, as well as currently used Bizhub C360 - C280 - C220.
            • deep
              • Jun 2008
              • 208
              Good call jam676, your's at professional level products.
              See what would it be at amateur level....
              Kenny
              • jma676
                Expert Tech
                • Mar 2009
                • 324
                Great Amateur Level!!!!!!!!!!!!
                And Other Amateurs Level.....
                With all due respect Xante , Great machine !!!!!
                • mrwho
                  Major Asshole!
                  • 4299
                  Sorry for continuing this off-topic, but that machine can't be all that bad. Because either that guy with red shorts hits like a girlie or the paper exit tray is very robust, since it took nine hits without breaking!
                  Mascan42
                  Ibid
                  • mascan42
                    • Oct 2008
                    • 480
                    Although it should theoretically be possible to use any sort of input device for authentication, it would require a device driver to be installed on the copier, and KM doesn't support anything like this.
                    • Stirton.M
                      • Oct 2009
                      • 1804
                      the chubby guy swings like a girlyman.
                      I would have taken that (HP???) to a greater height and dropped it, bit like another post around here, using a forklift to do it. And then run over it with the fork lift.
                      ---Groucho Marx
                      • Stirton.M
                        • Oct 2009
                        • 1804
                        Statistics Last Used in the Contact Center: 8/26/2010
                        Times Used in the Contact Center: 9
                        Related to Escalated Issue: No Created: 8/4/2010
                        Modified: 8/5/2010
                        Priority: None Specified Products Products:
                        bizhub 360
                        bizhub 180
                        bizhub 162
                        bizhub C350
                        bizhub C450P
                        bizhub C450
                        bizhub C252P
                        bizhub C252
                        bizhub C250P
                        bizhub C250
                        bizhub 350
                        bizhub 250
                        bizhub 200
                        bizhub 420
                        bizhub 160f
                        bizhub 161f
                        bizhub 160
                        bizhub PRO 1050e
                        bizhub PRO 1050eP
                        bizhub 750
                        bizhub 600
                        bizhub PRO 920
                        bizhub PRO C500
                        bizhub C352P
                        bizhub C650
                        bizhub C550
                        bizhub C451
                        bizhub C353P
                        bizhub C353
                        bizhub C253
                        bizhub C203
                        bizhub C200
                        bizhub PRO C6500P
                        bizhub 181
                        bizhub PRO C5500
                        bizhub C360
                        bizhub C280
                        bizhub C220
                        bizhub C652
                        bizhub C652DS
                        bizhub C552
                        bizhub C552DS
                        bizhub C452
                        bizhub 751
                        bizhub 601
                        bizhub 501
                        bizhub 421
                        bizhub 361
                        bizhub 281
                        bizhub PRO C6501
                        bizhub PRO C5501
                        bizhub PRO C6501P
                        bizhub PRO 950
                        bizhub PRO C65hc
                        bizhub 362
                        bizhub 282
                        bizhub 222
                        bizhub 363
                        bizhub 283
                        bizhub 223
                        Equitrac
                        bizhub 500
                        bizhub PRO 1050
                        bizhub PRO 1200
                        bizhub PRO 1200P
                        bizhub PRO 1051
                        bizhub PRO 1050P
                        bizhub C351
                        bizhub C352
                        bizhub C300
                        bizhub PRO C6500 Options:
                        None Specified Details Subject:
                        Vendor/key counter specifications and vendor-related firmware guide.
                        Description:
                        Solution:
                        The attached documentation lists all of the functions available for the MFPs when certain Vendor modes are enabled, and lists any special firmware that might be needed. This information applies to all KMBS equipment.
                        Vendors listed in the matrix:
                        If a function is listed as Not supported please use the Vendor-related Firmware updates document to see if Special firmware is available for the MFP in question.
                        ---Groucho Marx
                        • mrwho
                          Major Asshole!
                          • 4299
                          Whoah, that's a wealth of information. Thanks, Stirton!
                          Mascan42
                          Ibid
                          • Stirton.M
                            • Oct 2009
                            • 1804
                            Campus Card System - Card Loaders - Prepaid Cards - Vending Cards - ITC Systems
                            Equitrac: your intelligent printing management software. Securely print documents, minimize costs, and reduce network security risks.
                            These are the only two I could determine use barcode as one option. The other vendor interfaces use much more advanced methods, smart card, biometric.....
                            ---Groucho Marx
                            • Stirton.M
                              • Oct 2009
                              • 1804
                              Anytime mrwho....
                              ---Groucho Marx
